Transmission Temperatures?
Jeepkid
Puyallup WA
2010 Dodge Ram 1500 TRX 4
Just curious what everyone else is floating for the temps that their trans is running.
Mine seems to be around 160 to 170 and as high as 199 when towing, im very concerned with keeping the transmission working at a proper temperature i dealt with a grand cherokee that had the trans replaced and numerous attempts at aux coolers leaking etc i do not want to deal with this truck burning up the trans on me.
HLram
2012 and 2007
Hemi 5.7 in both
mine runs between 145 and probably 160 or so when driving (I think), but i have had it up to 210 before when towing in hilly country. The dealer told me they put synthetic fluid in from the factory, so it should be good. I had my fluid changed at 35,000 miles because I am a little rough on my truck. I do maintain it religiously though. I think you are ok on your temps.
09SMOKINHEMI
TEXAS
mine runs to about 155 when doing a lot of city driving, probably around 145 on the highway
CDN Ram
Ottawa Ontario
2014 Laramie
6.7L CTD
Bump!
Would like to hear from anyone that drive a CTD, mine seems to run around 170'F on the highway, I think this is about right but would like someone else to confirm theirs is about the same.
NYCruiser
Yonkers, NY
Operating temp for the 5-speed and 6-speed trannies is 80-240 f.
Over 240 you are overheating and should get an alarm. Under 80 it will be modifying operation, like disabling TC lockup and holding shift points.
If you are going to tow, my advice is to be gentle with it until you get it over 80f.
CDN Ram
Ottawa Ontario
2014 Laramie
6.7L CTD
Thanks for the info NYCruiser, those number are great. The truck is new and I'm trying to find out what is normal.
