Transmission that sucks
josie jarrett
2014 6.4 6 speed auto 4x4 im told it is in limp mode 4th gear is as high as it will shift up to. Codes are 729,735, and 871. Any idea where I stand with these codes. I need help only had the truck 2 weeks.
SouthTexan
408 CTD
Seems like a faulty line pressure solenoid. There was a recall on that if I am not mistaken. Hopefully it did not burn up your overdrives.
J
josie jarrett
Dealer service manager said I would also have to have an oil cooler when I asked why he said it was not operational then he made reference to my condensing unit???????????? Am I lost here or has technology just past me by.
atom13
USA
Na
Na
Its true dealer replaced mine when they replaced my transmission
J
josie jarrett
How would a transmission cooler become inoperable? I understand contaminated with debris. Maybe just a poor choice of words.
Not sure if it's the same on the 6spd trucks but the 8spd transmission cooler is the top couple rows of the same assembly as the AC condenser. It's just a coil, wonder why the dealer can flush it out.
Ratket
Arizona-
Money....
Pools of money...
They literally swim in it... and we are paying for it...
Sorry had to..
but ya that sucks..
J
josie jarrett
FYI the dealership near me gets 115.00/hr. Took truck in for estimate on transmission charged me 2 hrs on transmission never dropped the pan. gave me the codes and said the atf had debris in it. I pulled a sample looked at it at 300 power nothing I could see smells and looks new. They also charged me a hr for a gas cap code they read when they pulled the trans codes. I DO NOT think they want my business.
Ratket
Arizona-
Nope... they just want your MONEY...
Thieving mother F**k*r*
SouthTexan
408 CTD
Ask @RamCares to help you out with that. They are the Ram representative on this site.
RamCares
n/a
n/a
Ok so newest problem...My Vin number does not show up on any data base...like it doesnt exist ...what would cause this?
Awesome thank you so much!
Hi josie Jarrett,
We'd like to look into this a bit further. Please send us a private message with your VIN and current mileage.
Thank you,
Lydia
Ram Social Care Specialist
J
josie jarrett
OK The other half dropped trans pan today. He said it was just the normal debris in the pan and on magnet. The magnet had a layer of debris about .010 thick and nothing of any size. I changed both filters, pressure sending unit, and replaced 11 quarts of ATF. Test drove and the same result drives good get 1 hard shift and it is back in limp. With no debris in the pan that confirms my overdrive clutch pack is good. Is that correct? Can I assume that the problem is in the shift solenoid or value body? If so is there a after market brand that is better than OEM? Should I just rebuild this valve body and replace the shift solenoid?
ameer73
