Transmission
Jimmy68
Lethbridge Alberta Canada
5.2L Magnum
Hey.
It doesn't like to shift to O/D until it's well warmed up or I let off the throttle.
So, when I go to work I usually drive about 10 miles of highway before it starts behaving right. Sorta.
If at say 5 miles I back off the throttle it'll shift but doesn't want to stay there. It will if I feather the throttle and maintain speed but soon as a slight incline and I have to maintain, BAM, shift to third. Seems forth is kinda pointless.
Stock gears and stock size tires.
My question is WTF?
Merc225hp
NA
truck
gas
Couple of things
Check ctv cable for adjustment
Test tps make sure it's in spec
On the one kooler line there might still be a check valve, get that ******* thing Outta there if it still has it.
