Tri Fold Tonneau Cover Poor Fit
RickOnt
Ontario , Canada
I got a Trifecta tri fold tonneau for my 2018 Big Horn short box
Anyway that piece of plastic chit on top of the sides at the front of the box is creating a poor fit.
Has anyone dealt with this issue?
Can it be fastened down tighter?
Thanks
Rick
RickOnt
RickOnt
Ontario , Canada
Well I did some adjusting and I have it 'OK' but not great!
With the Tonneau on and tailgate down you can see a little bit of daylight under the Trifecta weatherstripping and that plastic side rail cap.
I bought some foam weatherstipping and am gonna put a small piece beside the cap.
That should work.
13ram1500crew
Ontario
HEMI
Can you post a couple pictures of the gap and fit? I was thinking of getting the same cover.
JB1
Houston, Texas
the bed rail covers kinda stick up at the front like they need to be trimmed or something right?
werdna1977
Ontario, Canada
I had the same issue with my gator trifold soft cover which is made in the same factory as the trifecta. I could not get it to sit tight at the front. The tighter i clamped it the more gap it made. I did have to trim the the bedrail cap as JB1 said above which helps a bit. I didnt want to dea with it anymore so i switched it out to a hard bifold flush mount and i couldnt be happier
RickOnt
RickOnt
Ontario , Canada
I have not been in any rain or snow So this might not be an issue
Just one of those things that are obvious now but I overlooked when buying tonneau.
I just really like the Trifecta as it is very easy on and off as I do remove it to put my ATV in the box.
RickOnt
RickOnt
Ontario , Canada
This is a pic from the outside, You can see the side rail cap and hoe it is preventing the weatherstripping on the tonneau from touching the bed.
I guess you could cut the side rail cap But I really do not want to be cutting my new truck!! LOL
Reactions: JB1
hotrod45
Home
Get some tape for bedding a cap (adhesive one side only). It'll likely take two layers to correct the elevation difference, but that will prevent the strip on the cover from being distorted.
JoshR104
I had the solid fold 2.0 on my 1500 and it never got water in the bed even though it looked just like your picture with the gap.
I wouldnt worry about it until you see water in the bed after a good storm then maybe add in some extra stripping. I cranked mine down pretty tight so never had any water in the bed from rain.
RickOnt
RickOnt
Ontario , Canada
Yes I think the weatherstripping will work,
But I am gonna try to find a top rail protector for the front of the bed
I feel that would be the best
I just need to find a supplier here in Canada.
hotrod45
Home
WILE E
Tullahoma
The link goes to a page that says front, but then it says that the part installs on the top of the tailgate. They might have the part there somewhere, but I didn't find it.
That part is for the part of the bed right behind the cab, not the tailgate.
hdoggie24
Huntington Beach CA
When I went though the link. These Westin front cap protectors are not available for the 4th generation rams. I went to their website and doesn't list our truck for them. Thats too bad because I would like to get one to match up with the factory side bed rails
WILE E
Tullahoma
Do you think there's much difference in the generations. It looks to just be a piece of plastic c-channel that glues to the top edge of the bed and wraps around the inside and outside. For $30, it might be worth a try.
hdoggie24
Huntington Beach CA
I don't think there would be much difference. Im gonna likely order one through amazon and if for any reason it doesn't work out I will return it.
ameer73
