truck height
usaf2006
North Carolina
My work has a 7' clearance restoration. How tall are these trucks stock? Anyone got a sec to measure for me?
GlOcKnRaM
Mebane, NC
5.7L V8 Hemi
You're good..if all stock you're probably around 6'3" give or take
usaf2006
usaf2006
North Carolina
For a 2500? 2wd or 4? My 06 1500 4wd sits at 6'6. All stock, on 265s.
2robinhood
2016 Ram 3500 SRW crew cab
6.4l gas
This should help answer you question.
Looks like the tallest is @ 79.8"
But keep in mind, these measurements might not include cab marker lights or satellite antenna which would add another 4 inches.
Hope this helps.
NewBlackDak
6.7L Cummins
My XM antenna scrapes on the 7'3" PVC pipe marker in the parking garage at fiancé's work. I keep it on the first level, which leaves me about 2" clearance. I can't pass through the ports to the other levels.
Skrap
Orange County, CA
2015 Laramie MegaCab 4x4
Occasionally is drive my stock 2500 MC on 275s into one of the local parking structures. I fit on all levels with about 4" of clearance. It gets a little hairy on the transition a to the inclines as the roof gets a bit closer. I find myself bobbing/ducking my head everytime I drive under one of the concrete beams going across the structure.
usaf2006
usaf2006
North Carolina
Haha thanks guys. Just making sure it would a new truck would fit as I have 7ft clearance at work.
mtofell
It's a funny illusion how it seems like you are going to hit for sure. Then, you get out and look and there is like 8" over your truck.
I always duck my head too.... like that's going to help :)
init6
Marion, OH
My 2500 4x4 stock height with 35s will clear 7' at the drive through car wash.
Mine is leveled with 35s and the radio antenna hits on a 7 ft bar in a parking garage. Clearance lights and sat radio antenna clear though.
