Truck shutting off!!
jwndriver14
So 3 times now my '10 ram with the hemi has shut off by itself while driving. Two times when I was braking to make a corner and once while just braking. Any ideas what it could be??
Sent from my SM-G920V using Tapatalk
jwheeler
Washington
Is the check engine light on? I can guarantee it is not the EGR.
SilverStreak88
Houston, Texas
5.7 Eco Gasser
You can guarantee? So you've had this issue before and you arrive at this thread and claim dominance? The EGR won't throw a code until it finally goes out completely.
jwheeler
Washington
Hahahahaha just trying to help, not make a wild ass guess. His 2010 does not have an EGR valve.
jwheeler
Washington
They quit using EGR valve when they first went to VVT. You are able to get enough scavenging of exhaust gasses with the valve overlap.
J
jwndriver14
No it's not throwing any codes or anything.
R.L.K.
Bristol , Tn.
My understanding of the system is just like jwheeler.....
sisupower
I'm having exact same issue. But no check engine light. Traction control, ESP BAS, service 4wd lights are all on. Cruise control inop and brake lights stuck on! Holy crap what the heck is wrong??? Anything guys??
[emoji832]HAMMERHEAD[emoji832]
Mpotatoe
5.7L hemi
I recently just had this problem fixed on my truck. It randomly would shut off while driving and it happened around 8 times. I took it to the shop and it was a simple corroded wire that needed to be replaced. I've been driving it for about two weeks now with no more issues.
sisupower
Where was the wire located? And this was a 2010 ran hemi?
455calais
Check your battery cables may be loose. Mopar tech.
sisupower
I've checked battery cables on both ends. Good n tight
J
jwndriver14
I guess I'll check my cables yet to but I doubt they're loose.
R.L.K.
Bristol , Tn.
What wire ? Location and description please ...
dakota18
