Truck stuck in driveway.....
Thewetdream
2022 Dodge Ram Big Horn Crew Cab 4x4
Hey guys I have a 2015 Ram 1500 5.7..... the driver side sheered the first and last cylinder manifold bolts on that bank...... got one out successfully..... still working on one. My biggest issue is the driveway is getting paved tomorrow and the truck is parked on the driveway. I cant turn the key to on and put the truck in neutral when its not running like i could with any other truck. Im trying to get it so i can roll it down the driveway so the guys can work in the morning and its out of the way with out actually firing the engine up..... i really want to avoid running the engine even if its for a split second with the manifold off. If anyone has any suggestions on how to get around this would be much appreciated lol
BWL
Embrace the skeptisism
BC Canada
There's a panel just to the left of the steering column. Pop it off and there's a neutral release lever behind it. Make sure the e-brake is on when you pull it so it doesn't accidentally roll away.
Thewetdream
Thewetdream
Just below the Headlight switch, you will see a blank panel & the E-Brake release
Behind the blank panel you will see a red strap
watch this video, it will help you to understand better than i can explain it
YOU ARE THE MAN!!!!!!! I get out of work at 11pm tonight ill be going home to do this. Thank you so much!
Thewetdream
Thewetdream
...... cant wait to get this other bolt out...... my body cant either ..... truck is beating the shiiiiiit outta me
I have watched a few videos on removing manifolds & extracting broken bolts
It does not look like fun
huntergreen
Marine Corps Navy Badge
great video !!!
89grand
Phoenix, AZ
2019 RCSB
This is why I join forums for every vehicle I own. I take notes of failures, and how to remedy them, even when everything is fine at the time, so I don't end up stumped or paying for a tow truck when it isn't needed.
Thewetdream
Thewetdream
I’m still on the second bolt ..... starting to feel defeated and quite nervous about screwing this head up...... I wish a socket would fit over this easy out
BWL
BC Canada
If you have the right 12 point socket it might. Assuming the easy outs you have are square head.
Thewetdream
Thewetdream
yeah they are square ...... i went through my extensive sockets drawer in my tool box and thought a 12 pt would work too and i cant find one to work....... i think i may go to home depot in the morning.
The best way to remove broken bolts is to weld a nut onto the broken bolt, if any of the bolt is sticking out.
If the welder is good, they can sometime weld a nut onto the bolt, even if it is broken off flush
RoadRamblerNJ
Mountain City, TN
392 Hemi
LOL, You just told us all exactly what we would need to know in 3 sentences!
Props to GTyankee for the video, don't get me wrong. I've seen some of MCM's vids and he takes a while to get to the point sometimes.
RoadRamblerNJ
Mountain City, TN
392 Hemi
Spent an hour trying to get a nut started putting a starter in a sb Chevy. I used up all the curses I knew in 3 languages. Just couldn't get it to catch a thread. Arm got so weak, I dropped the damn thing onto my face! I invented a 4th language curse words like the father fixin' the furnace in "A Christmas Story". My wife said go eat the sandwich I made you. OK, I did, with a beer.
Came back out, slid back under the car and badda bing, badda boom, right the F in! 1st try.
Sometimes you just need a sammich 'n a beer. Good luck bro.
dakota18
