cuchulain
2009 regular cab 2wd with 6 cyl.
When the truck sits awhile it doesn't want to roll after you put it in drive. You have to step on the gas to overcome some type of resistance. So much that i get stuck parked on the wet grass. I figured I had a caliper not releasing so I jacked up the wheels individually and they all seems to roll ok.
Any ideas or is anyone else having the same problem? Thanks
