Truck won't start after successfully installing Diablosport 87 octane tune
Michael
In an undisclosed bunker
UPDATE*** I got ahold of tech support this morning (turns out I don't have to be at work till 3 today) and they sent an update to my tuner. I installed the update, plugged it in to my truck and everything started as usual and the fuel pump primed like it was supposed to. I reinstalled the stock tune and everything fired right up. Now i think my only problem is a bad cat. converter as i am hearing rattling coming from my right converter and rough idle.
That’s great that it was an easy fix. Too bad it took so long to get.
I know the voices in my head aren’t real, but man, do they ever come up with some great ideas
Michael
Yeah I'm super relieved. The guy said it was a problem in the firmware of the tune I installed...
Now it’s time to get a custom tune. They’re much better then the canned tunes that come with it.
Chrismb5.7
Chrismb5.7
Dandridge, TN.
Agreed, but it's okay. I'm just glad I got my truck back!
JohnnyMac
SouthWest Washington
2018 1500 Laramie / 2024 3500 MegaCab Laramie
3.0 EcoBurner / 6.7 Cummins HO
UPDATE*** Now i think my only problem is a bad cat. converter as i am hearing rattling coming from my right converter and rough idle.
Cats? You don't need no stinking cats.....
Jose Lomeli
California
I bought the Predator P2 Platinum for my 04 5.7 ram 1500, updated the tuner, installed the 87 octane tune successfully, now my truck won't start. After the tune installed it cleared DTCs, and after being told everything was successful I unplugged the tuner and turned the ignition on. Heard everything power up but now it's like something is trying to power on but can't. I plugged the tuner back up to my truck in hopes of just going back to stock and it told me it could not recognize my pcm... But it gets a lot better..... I took my tuner back inside to my computer to check if I just needed and update again. No I did not. Took it back out to my truck, plugged it in and it asked me if it was the same vehicle the tuner was last used on, I clicked yes, it then told me it could not ID my vehicle and proceeded to reset itself. Since then I've just gotten the "cannot ID vehicle" message. My obd2 scanner will not communicate with it either. My battery is not dead, when I open my door my odometer shows on my dash, insert the key and the door chimes sound, turn ignition on, my radio comes on, dash lights illuminate, but no start, not even a turn over. Just the sound of something that sounds like it's stuck in a loop. Please help me out, I love this truck too much. I can post a video of the noise mentioned if needed.
ChloeBrooks
