Trying to drop one side of the front axle.
newrammer
5.9 v8 magnum
Ok so trying to install my 2.5" leveling kit, I was doing it by dropping one side of the front axle at a time so the spring will come right out at full length. But, my axle would only go so far. Is something holding it from going all the way? Drive shaft maybe?
Merc225hp
NA
truck
gas
Track bar, steering linkage, shocks, possible control arms. These are all things I remove or undo when dropping the front diff to install springs and coil spacers.
newrammer
newrammer
5.9 v8 magnum
Ah okay thanks Merc. I'll have to wait til my next day off, no more day light.
newrammer
newrammer
5.9 v8 magnum
Should i try to use spring compressors on this while also dropping it? Or will dropping it be enough.
ramburger
get external spring compressors so ya dont gotta disconnect all that crapass crap.
mda8569
Vandalia Ohio
5.9 magnum
What do you have to disconnect when using the compressors? Shock...
Merc225hp
NA
truck
gas
Dropping that **** is so easy it hurts. No spring compressors are needed for this job. Be a mech or be a *****. Shocks have to come out no matter if you use a spring comp or not. Take less time to drop those parts than to set up spring comp tool on the springs.
newrammer
newrammer
5.9 v8 magnum
Ok that's what I figured, I also know how dangerous compressors can be....seen too many videos lol
Merc225hp
NA
truck
gas
There you go full on right, like I want to compress a spring 3" and work with it, noda chance in hell thank you. Leave the control arms be they should be fine, I have to drop them when I do the 5-7 inch springs.
ramburger
oh well call me a ***** then
Merc225hp
NA
truck
gas
Seams today is no forum filter day, did not mean to upset you.
So do you shave it or leave it hairy? ;)
