turbo actuator replacement DIY?
JamesSoltis
I am pretty sure that the actuator on my '14 3500 with Cummins 6.7 needs replaced. I have watched the Youtube video from MotorCityMechanic using the actuator from Geno's. Looks simple enough for DIY.
I am not a mechanic but wonder if any other non-mechanic DIY's have done this and your experiences and recommendations.
Thank you
alaska12v
Alaska
You can do it yourself. You need a Bluetooth odb2 tool and Alfa odb app which is android only . You have to calibrit first step is done with acuator off the truck then the second is with it installed
J
JamesSoltis
Geno's claims that their unit is pre-calibrated. Does that sound right?
trap shooter
grass valley cal
6.7 cummins
Piece of cake to replace and you don’t have to flash it or anything self flashing Got mine at city diesel. Good luck
