Turn key and nothing
BillyBucks
I'm going freakin crazy. I have a 2012 ram 1500 Laramie with a 5.7 Hemi engine. Not sure what the problem is but periodically you turn the key to start my 1500 and it is completely dead ,there is nothing, absolutely nothing. There is no lights, there is no cranking sound, there is complete silence. I have to let it sit and not panic and in about 3 minutes all the sudden the door locks pop the lights go on and it will start. Dodge has no idea what's wrong so I ask any of you if you have experienced this and have found what is causing this problem. Thanks look forward to hearing from anyone.
Ratket
Arizona-
The chip set in the key/fob could be going bad or dead- ^ like he said try a different one
EvanYJ350
2016 2500 CC Air Susp
6.4L 392 c.i.
Had the same totally dead issue. Called tow truck. They took it to dealer, took it off the hook, and vroom...started right up. No codes stored, nothing wrong. Trading it in next month.... 2500 on order....
I was parked near High Tension Power Lines, and a John Deere dealer that had a lot of computer stuff. Could have been electrical interference ???
