U1437 Code on 2011 ram 3500 6.7 cummins
TTKC
KCMO
5.9 Cummins
2011 dodge ram 3500 cab/chassis model
So recently took truck in. I bought a brand new TCM and had it installed and programmed back on the truck. This was because of a bunch of codes popping on the truck.
It fixed them all except one and we're at a loss here now.
Code still popping is U1437. This code is TCM related. It pops up as "U1437 IMPLAUSIBLE INTAKE AIR TEMPERATURE MESSAGE RECEIVED".
Cool so I replaced the air temp sensor. Didn't remove the code. Did a little more research on that code and found that it could also mean "
transmission temperature sensor and transmission fluid temperature sensor performance detections".
I guess I can't exactly get a solid answer on what the U1437 code means and what to do next.
Anyone had this issue?
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Was the new sensor a Mopar one or after market? Rams don't like aftermarket sensors.
If it was an OEM sensor, I would start tracking down wiring / connector problems. When checking each connector from the sensor to the ECM, look for corrosion , loose / bent pins in the connectors.
T
TTKC
KCMO
5.9 Cummins
It was a Mopar sensor and the TCM was from Mopar as well.
