ND Wind
2022 RAM 1500 with 12" Uconnect. When starting truck using remote start, the Uconnect system will be running when I get in the truck then freeze typically when I put truck in reverse. System will eventually try to reboot but never successfully. When the screen does come back up, sometimes it is moving / dancing around, other times it will come back to the last screen that was up but no menu buttons, so you cannot control HVAC, radio, nothing. The radio will be on but you can only control volume. The only solution has been to turn truck off for a period of time then start normally.
This has been going on intermittently for nearly a year and seems to be getting worse. I don't recall if does it when starting normally (no remote start). I want to say it has but it's not as common as when starting with remote start.
My Uconnect version is FCA-MY24.U35.26-PROD. Is this the latest version? I am, and have been all along, connected to home WiFi.
Appreciate any guidance on this. I did not want to take to dealer yet until I had more information to provide to them so I can avoud the dreaded "can't reproduce the issue".
