Uconnect fuse? No signal for Sirius
2batruck
Starting yesterday I suddenly got acquiring signal message on my stupid Uconnect radio. I want to try to remove the fuse for about 30 min but I can't seem to find the right fuse. It's for a 2013 ram 1500 hemi. Help is appreciated
Ramzaq
Northern California
2009 CC 4X4 3.55 Big Horn
Check the TIPM module in front of the battery, that is where the fuses are located. Your fuses and slight description should be listed on the under side of the top cover.
Also check your antennae connection to your radio for the sat.
baum
savage, mn
2015 Laramie
its built in to the radio so you will have to try and pull the fuse for the radio. most likely if its trying to get signal something is going on with the antenna not the radio
WhiskyTwo
New Jersey
I am also trying to locate the fuse, but M12 is not on the cover.
View media item 26534
clifford15
RI
CTD
Search for secret radio fuse. It is near the master cylinder.
dbdbasd
