Uconnect update failed now stuck in boot loop
Cade Sumrall
United States
6.7 l Cummins
I recently purchased a 2015 ram 2500 with very low mileage. Everything on the truck was perfect until I noticed the radio would freeze up and it would take 1 or 2 ignition cycles to get it working again. Well I Figured I would try to update and see if that would fix the problem. I followed all the steps recommended by dodge as well as several forum posts I found on similar issues, but my radio will begin the update and then give me a screen that says "update failed please remove USB" at unit 14 every time I have tried 5 different USB drives all of different manufacture and it's the same result every time if anyone has any advice I'm all ears as my radio is now useless, and I've had to remove the fuse to the radio so as to not drain my battery since the boot loop repeats even when the truck is off. Thank you so much for your time and any help y'all may be able to provide.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
The only thing that has worked for me is hooking it up to a trickle charger and letting it sit. I got one to update doing this but it may have taken a day or two. Insert the original USB you started with. What size was the original USB?
C
Cade Sumrall
United States
6.7 l Cummins
it was a 32gb PNY. However I reformatted it after the install to insure it was fat32 but I did save the original swdlLog file from the first attempt before it was reformatted. (also tried a 16gb sandisk, and 2 16gb no-name drives) also are you saying just put in the usb and keep the truck on a trickle charger and let it keep trying to update
C
Cade Sumrall
United States
6.7 l Cummins
When I try this with the original usb should I put that swdlLog file from the first update attempt back on the thumb drive?
C
Cade Sumrall
United States
6.7 l Cummins
was going through the log file and found this.
"Installing unit 14 HD Update
Got the unit installer for HD Update
percent = 100%
status.value = 0, status.string = success
qkcp done
i2c-omap35xx operation start
?:0: attempt to compare number with nil
stack traceback:
?: in function <?:147>
?: in function '?'
?: in function <?:98>
(tail call): ?
(tail call): ?
[C]: in function 'xpcall'
?: in function '?'
?: in function '?'
?: in function <?:667>
?: in main chunk
[C]: ?
ERROR: INSTALL ERROR
Software Update failed, see 'swdlLog.txt' on the USB stick for more details
Eject USB for RESET"
Any ideas???
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
percent = 100%
qkcp done
stack traceback:
?: in function '?'
(tail call): ?
(tail call): ?
?: in function '?'
?: in function '?'
?: in main chunk
[C]: ?
Any ideas???
32 might be too big (I think the recommended size is 8 with 4 being minimum). Try the 16 and throw the log file on it. Just set it and forget it. Your battery will die without a trickle charger though. They can be had pretty cheaply at places like AutoZone or Walmart. If on the third day its not running its probably done for. Did you see what module 14 is during the install? The typical failure is Sierra Wireless Aircard but I thought that was module 13.
C
Cade Sumrall
United States
6.7 l Cummins
It calls module 14 "HD Update" and Module 11 is the aircard but I'll give it a shot when I get off work, and I'll keep ya posted.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Sorry, I see that in your prior post now...
chri5k
USA
Diesel
Is this the original 8.4" RA3/4 or did someone upgrade the truck to the 2018 8.4" UAQ/UAS with Android Auto / Carplay?
C
Cade Sumrall
United States
6.7 l Cummins
As far as I can tell it’s the original however it could of been changed before I bought it is there a good way to tell now that it’s stuck in this loop? (I apologize for my ignorance I’m new to these uconnect systems)
C
Cade Sumrall
United States
6.7 l Cummins
Well it's been several days and it looks like this thing is bricked made an appointment with my local dealership lets see what they say
RamCares
n/a
n/a
Hey Cade-- sorry to hear about that. Let us know how your dealership visit goes and reach out if you need any assistance!
Courtney
Ram Cares
ARKLima
Idaho
Courtney
Ram Cares
I am in need of help, stuck on the boot loop and I have tried almost everything that has been mentioned on the internet. I have an appointment for the 25th at a local dealership…UConnect said to call them if the dealership tries to charge me. Is that true?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I'd get it in writing...
