Uh oh...
ramthis9501
Oklahoma
5.2 V8
Check engine light came on... It did it the other day and I disconnected the battery and it went away. It came back today. Gonna run it to oreileys tomorrow and run the codes. It sounds and runs fine, what's the deal?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Possible Evap but those pop more on the 3rd gens. If its all running fine its prob a sensor or something simple.
ramthis9501
ramthis9501
Oklahoma
5.2 V8
So does the sensor need replaced or just reset?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Normaly replace.... get them to pull the codes and we will work from there.
RubberFrog
We don't really know what the deal is until we see the code. It could very well be something as simple as getting the flux capacitor flashed under your emissions warranty.
OklaHemi
new age hemi
or headlight fluid change. go to advance in moore theyll tell you the codes
ktm1217
White Mills, PA
5.2L 318ci Magnum
Sounds you have yourself some worn out muffler bearings..or worst case scenario is your piston pull-back springs are shot.....
joshhhh
