Unlock issues
nutshot
When I got home today, as I was sitting in the truck I tried to unlock the other doors by pushing the unlock button on the door panel. Nothing happened. I kept playing around with it and noticed the key fob wouldn't unlock the doors either. If i push the fob or the door panel button enough it does seem to eventually unlock but something is definetly not working right. Lock seems to work on both but I'm not 100% on that. I tried disconnecting the negative battery terminal for 20 mins and when I hooked it back up the problem resolved for about 6 unlocks and then returned. Anyone have any idea what's going on?
Thanks
RAMTRPR
"Enjoy The Little Things"
Brentwood, CA
Mine did the same and now the buttons on the doors work fine bu both my FOBs will not work. I think the WIN module is the problem, but not wanting to spend the $500 plus to replace it.
I have the PIN to reprogram the FOBs with AlfaOBD but if they don’t work and I try, I may be dead in the water.
Does yours have remote start as well? Does that part work?
