Up north
pinenut
Whitehorse
-27 C last night, consistent -20 going to town today. Just noticed "cal" in tiny letters in the main info cluster. Stayed up for the first ten miles. Coming home it stayed up for the whole 20 miles. Can you tell me what it means? '10 1500 Laramie, 5.7 l. Many thanks. Carl
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
Pinenut
You brought up a question that not many of us has ever seen
From the Owners Manual
Automatic Compass Calibration
This compass is self-calibrating, which eliminates the
need to manually reset the compass. When the vehicle is
new, the compass may appear erratic and the EVIC will
display CAL until the compass is calibrated. You may
also calibrate the compass by completing one or more
360–degree turns (in an area free from large metal or
metallic objects) until the CAL indicator displayed in the
EVIC turns off. The compass will now function normally.
NOTE: A good calibration requires a level surface and
an environment free from large metallic objects such as
buildings, bridges, underground cables, railroad tracks,
etc.
Manual Compass Calibration
If the compass appears erratic and the CAL indicator
does not appear in the EVIC display, you must put the
compass into the Calibration Mode manually, as follows:
1. Turn ON the ignition switch.
2. Press the UP or DOWN button until the System Setup
(Customer-Programmable Features) menu is reached,
then press the SELECT button.
3. Press the DOWN button until “Calibrate Compass” is
displayed in the EVIC then press and release the SELECT
button.
4. Press and release the SELECT button to start the
calibration. The “CAL” indicator will be displayed in the
EVIC.
5. Complete one or more 360–degree turns (in an area
free from large metal or metallic objects) until the “CAL”
indicator turns off. The compass will now function
normally
P
pinenut
Whitehorse
Pinenut
etc.
button.
EVIC.
normally
Many thanks Gtyankee. I don't know if the temperature had anything at all to do with it, but the issue seems to have resolved itself. OR if the back-and-filling of getting in and out of our snowbound parking area resulted in a 360. Whatever, now I understand it.
Cheers, Carl
