Update on my truck
Tolson93
Northern MN
Well today i heard they had to shave or plane the heads on my truck. So, that means they were warped, and thats due to heat i take it? BUt i have a question if i can get this truck back for real cheap is it still worth it? or since the heads were warped to heat could other engine problems flair up in the future?
HemiBabe
DFW
Hopefully someone will chime in for ya
PCA4208
Albuquerque, New Mexico
Shaving heads will most likely result in a bit higher compression ratio depending on how much they had to shave off. But if anything that'll help you out. You should be fine though.
WhiteExpress
Midland, TX
One mechanical failure does not mean the truck is a POS.
Could have been a fluke. My friend had an injector die on his Cummins.
The truck was and still is a beast, mechanical components fail.
These things happen. If you like the truck, and get a good price on it, I'd say go for it.
Tolson93
Tolson93
Northern MN
yeah right now they want to charge me 1800 bucks for the fix, and are trying to work out some sort of payment help for me since i cant come up with that kind of money out of no where... still fighting to get it cheaper cause i had the damn truck 23 days and this happened. hope it all works out for the better
