Used factory projectors
2010 Infantry Vet
Butler pennsylvania
Ok so i finally bought used factory projectors. Surface are is like new, passenger light is missing 1/2 of the mounting tabs so i can still mount it. Driver side is missing all tabs, and has condensation. Will i have to unseal the the drivers side to get condensation out? I hsve heard inserting silica packs works, but where exactly do i insert them?
I only have a pic of the passenger side. Not fogged up drivers side. I paid $300/pair.
2010 Infantry Vet
2010 Infantry Vet
Butler pennsylvania
For those of you that have retrofitted, are these morimoto projector lenses sold in a pair, or individually? Also does bi-zenon mean it is a high and low beam all in one?
Purplert
Comes with two projectors so $140 for the pair.
2010 Infantry Vet
2010 Infantry Vet
Butler pennsylvania
So if i order a set of HID bulbs for these, will they work for high/low beams, or do they have to be distinct bi-xenon?
I would rather spend the money on bulbs once and do it right. Thanks.
Purplert
Bixexon simply has to do with the the projector itself (its a solenoid built into the projector that has two wires a +/- you connect it to the high beams that way when you click the highbeams the solenoid drops giving you a high beam has nothing to do with the bulbs so any D2S bulb will be fine if your going with those Morimoto D2S projectors
OC455
Central NY
Yes, you get two projectors, bi-xenon is high/low beam. There is a shutter inside the projector that is activated by a solenoid as described in the above post. The shutter part is what makes it high & low beam.
They make low beam only projectors which have a permanently affixed shutter. High beam projectors do not have any shutter.
You'd need the bulbs, which ever Kelvin rating works for you. 4500k is described as a warm white (yellow) 5500k is the white light which seems like everyone goes for the most. 6500k has the bluish color to them.
2010 Infantry Vet
2010 Infantry Vet
Butler pennsylvania
Thanks for explaining that. So what about fixing the condensation, where do i put the silica packs?
