Vararam intake cause any rubbing?
dhows31
Mississippi
I heard a while back that some folks were having issues with the intake rubbing and wearing out that heat shield on the underside of the hood. Before I bought one I wanted to see if that was still an issue
Tray Burge
On the porch
No problems here.
Reactions: CTD
eljefe
Moyock, NC
Mine sits crooked, passenger side higher because of the a/c line. I don't see any rubbing on the hood heat shield.
Pull Ya
Cedar Creek, Tx
I've had 3 4th Gen Rams and had a Vararam on each one of them. I have never had the problem you describe. The Vararam seals against the heat shield on the underside of the hood but I have never seen an indication of "rubbing".
Jay
dhows31
dhows31
Mississippi
Alright great so what about rain and such? Is that causing any issues I know they have the holes drilled or whatever to drain the water but has it caused any issues?
Dodge This
Are there any fitment issues with the new sport hood vs a regular hood?
JIMBOX
:) Any trouble, you just adjust the length of the THROTTLE BODY TUBE !
poxwiMhfj
--JIMBO
Pull Ya
Cedar Creek, Tx
No fitment problems with my 16 with the sports hood.
Jay
CTD
Southwest, VA
I drive through heavy rain often at highway speeds and I have never seen so much as a drop of rain on mine or had any issues what so ever. Now if you plan on off roading through huge mud holes you may want to go a different route, but for every day driving you shouldn't have any problems.
KAKA
