Racer196
I have a 2014 ram 1500 longhorn Laramie with air suspension. I live in iowa and starting this past winter (first winter I owned it) the air suspension started acting weird. One bag would deflate but would re inflate if I put it inside. But it slowly got worse. And now both fronts wont stay inflated. the rears are semi deflated. The compressor seems like it works or at least some because if I pull a line it air comes out. Ive had it into the ram dealer around here and they cant figure it out but. The dash has immediate air suspension service required when I start it up. I have 80000 on truck now. I'm tired of the horrible ride so my question is what is everyone using for the delete kits I don't really want to lift the truck but don't want junk either. Also I do want to put aftermarket bags on rear to help with towing. I'm thinking about get the ones that go inside the springs. I was thinking about bilsteins but what os everyone else using for shocks and springs. Links would be great. Or part numbers. Thanks in advance.
BTW you should learn to read better,i'm not the one who said "people are tired of answering the same question". Like i said,be useful for a change,you still haven't dug up the thread you were referring to.Instead of babbling on about me,get off your asss and help the OP out,and find this thread you're talking about.With that i'm out,as you're boring the hell out of me now,have a good day sir
