Washer fluid pump
JayI
Mathis TX
Expensive fix for 15 dollar part. Total cost of fix is 400.00. All labor. The 2021 1500 pump is located behind the grill. The majority of time is in removing the grill. You need special tools to remove the grill. The pump is located so you have to take it in to be replaced. Anyone else have an issue with their pump.
Rain-X has a rep of gumming up washer pumps.If you've been using it,you might want to switch to a differant washer fluid
