Washer Pump not working
rlmuirheid
Cincinnati
4.7 Gas
Help
Put a new pump in but still doesn't work. Push the switch and blades will work but pump doesn't. Pump doesn't seem to be getting any power. Could it possibly be the multifunction switch in my 2006 Ram 1500
Rlmuirheid
PdPuNOme
Jersey
I would say it is the actual harness that plugs into the pump. I have a high end scanner that pull codes from the fcm and will show that, but even without one just try reseating the plug and see what happens. I have a bad harness and sometimes have to replug it in pushing it on fairly hard. If that does not help then I would suspect the fcm or wiring. multi function switch last.
