Water Getting in from Passenger A Pillar
Daw14
South Florida
I would stay away from silicone, it is temporary. If you use the search for our site search third brake light m-d This is the brand Home Depot has and a bunch of us have had success for over a decade. You can find a close size , but some trimming is required. Put the joint on the bottom if it’s not shown in the search .
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
This is what I have had on there for nearly ten years now...
Grams
2024 & 2015
6.7 Cummins & 5.7 Hemi
Thanks but I'm not sure what you mean by the "high mount brake light isn't a thing" Can you clarify, please? Thanks
The “A” pillar are the ones at the left/right of the windshield.
The “high mount brake light”…(CMHSL) ….is above the rear window. They have been KNOWN to be a problem since the early 2000’s.
Rain and Car-Washing will get behind that CMHSL with a poor gasket and leak into the cab… soak the headliner and soak the carpet behind the rear seat and contribute to mold/musty-smell.
Re-Seal the SHMSL. (Butyl tape, such as used on RV’s and such works pretty good.)
If water is coming from the A-pillar…it’s most likely due to a leaking windshield gasket…but if it IS due to the CHMSL then it must be somehow being “channelled” around the headliner…. pretty difficult for me to imagine.
mtofell
Pretty sure this is the stuff from HD.
I bought my truck new in March of 2014 and within a few months my 3rd brake light went out. Pulled the cover and it was full of water. I called the dealer for warranty and they said they were aware of the problem but had no fix yet (seriously?). Got the exact product you picture and cut a strip to go around the top and down the sides between the lens and truck body (throw out the POS factory "gasket"). 10+ years later and my fix is still working just fine. The bulb actually failed again recently (10+ years later, presumably just due to age). Went to change it and it's dry as a bone and my repair that Ram apparently couldn't figure out is still holding strong :)
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Agreed, I've had mine in/out several times changing bulbs/adding cameras with the same window gasket from home Depot installed. It's a lot thicker but very compressable making a good seal (I did leave a tiny opening at the bottom to weep though)
