Water Leak at cylinders 4&6
RacerX
1999 Dodge 150 Laramie SLT
5.9L
My brother just bought this vehicle (1999 Dodge Ram 1500 Laramie SLT, 5.9L) and it had a "small radiator leak". So this past weekend we proceeded to replace the radiator and some other items. After getting the vehicle all back together and starting it up, we noticed white smoke coming out of the exhaust pipe. Also noticed water dripping onto the top of exhaust manifold at the #4 and #6 exhaust ports. It looked like the water was coming form the bottom of the valve cover. But there was NO water in the engine. So I'm guessing that it might a bad intake manifold gasket. But I'm not sure. I don't know if water runs through the cylinder head at this location or not. Any insight and suggestions are welcomed as I'm new at working on Dodges.
fonzyn75
Intake gasket failure is very common with these trucks all tho im not exactly sure if thats the issue it could be something to look into tho.
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Did you checkt he oil to see if it looked like chocolate milk?
ChloeBrooks
