Weather Alerts on Nav display
Jakbkwik
Hemi 6.1
‘19 Rebel ...So I’m getting weather alerts on my Nav display but they are all from the area where the dealer is located that I bought my Rebel from, which is halfway across the state. I’ve set up my home address in the settings but that didn’t change anything. Where can I find the setting to change where these alerts come from?
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Should be able to turn off TravelLink in the BCM config settings using AlfaOBD
M² Mods.
Bluesurf
Houston Tx
V8
If you have XM Guardian you only have to call them and they will correct your location. My XM Guardian traffic/weather came with my truck for 5 years free.
Mpgrimm2
SC
5.7L
Sorry to resurrect an old thread but is disabling the whole travel link what’s necessary to turn off those annoying weather alerts?
Yep.
SDARS Travellink Setting: Disabled
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
Yep.
Ok but when you disable the travel link, that disables the movie times, gas prices and all that stuff? Not that I use any of that, I’m just curious.
Where do you find that area of alpha obd to change that setting?
Mpgrimm2
SC
5.7L
ECU config 3:
corneileous
Podunkyville, OK
Thank you!! I’ve been sooo lookin’ forward to getting those alerts turned off.
So is this one of those settings that may take awhile to change? I selected that option and selected the value to NO but after waiting about five minutes and cycling the ignition on and off, the TravelLink is still there and usable.
