Weatherstrip between the cab and bed
Mineralram
Picked up my weather strip today at dealer. Cost me $ 18.75 taxes in
Sent from my SM-G900W8 using Tapatalk
Mineralram
Not sure if you can see it in pic but the edge that touches cab is not smooth either65fb4347fa325befaf4381c3b0a27d2c.jpg
Mineralram
Soory guys, got too busy on weekend gonna try for this saturday to do the job
Sent from my SM-G930W8 using Tapatalk
Hemi395
Hemi395
Cape Cod MA
I'm wondering if the bed and cab are farther apart on some trucks than others. On mine the weatherstrip is jammed up against the cab. So with that said, is there much adjustment in the bed to move it say 1/4" to the rear to stop this rubbing?
Sir John
Buffalo, NY
2016 1500 Rebel "Mopar 16" Special Edition
A buddy of mine has a 07 ram and sure enough, that seal is there and it is rubbing the **** out of his cab.
CLOUDL1GHT
Lone Star State
Cummins HO
Agreed. I still need to look at mine but if it was rubbing I'll be cleaning the area and hitting it with some red rustoleum paint to keep it from rusting.
Hemi395
Hemi395
Cape Cod MA
Anyone have an update on modding this so it won't rub?
Mineralram
Not yet sorry, still have not done mine.
mcaligiuri
2016 ram 1500 express crew cab
just fixed this now, it started on my 2016 500 mile truck. I cut the strip right before it touched the cab. Then bought 5/8 foam door seal and ran it on the cab to make the same seal in case the water getting on the gas tank was gonna be a issue
DavidN
Central Florida
I just removed mine.
Sure enough - pretty rubbed underneath.
I thought of just leaving it off.
Any concerns??
Hemi395
Hemi395
Cape Cod MA
Any concerns??
The fuel pump is right under that area (on a crew cab) so there's concern over water constantly dripping on the fuel pump if that is removed.
Hemi395
Hemi395
Cape Cod MA
Nice! Might look into doing something like that
Sir John
Buffalo, NY
I like where you're going with this and had I caught it when my truck was new I would had done something very similar. The only thing to keep an eye out on would be that foam you stuck on there. It can hold water and if you live in the rust belt, it will hold salty water in the winter time. This is why you see so many 3rd generation Rams with the rear fenders rusting through....oem foam holding water/salt there.
Hemi395
Hemi395
Cape Cod MA
This is an excellent point, didn't even think about that...
Mega-Hemi
US AIR FORCE '08-'18
Back in New York!
Just went out and checked mine. Guess I've got another project to add to the list.
Steve Holtz
