Weird 4x4 dash light behavior
SilverHammer
Kelso, TN
5.9L Magnum
After using 4L the other day, I have noticed the light on the dash now flickers on and off real fast while going down the road in 2H.
Any thoughts on where I need to start looking?
Sent from my SM-T813 using Tapatalk
SilverHammer
SilverHammer
Kelso, TN
5.9L Magnum
1998 Ram 1500 Laramie SLT 4x4 Quad Cab Short Bed Pickup
JohnnyMac
SouthWest Washington
2018 1500 Laramie / 2024 3500 MegaCab Laramie
3.0 EcoBurner / 6.7 Cummins HO
My 2000 Ram 1500 5.9 had a vacuum leak that caused it to not go into 4x4. I'd have to go in and out a bunch of times before it would lock and would have problems coming out. I'd start there, as it's a fairly common problem. My leak was down, under the truck by the front axle. Broken/cracked line.
SilverHammer
SilverHammer
Kelso, TN
5.9L Magnum
That actually makes sense to me because of the behavior I am seeing with the A/C vent door.... I suspected vacuum leak, but haven't noticed any drop in performance or smoothness of idle.
1998 Ram 1500 5.9L Laramie SLT 4x4 Quad Cab Short Bed Pickup
JohnnyMac
I don't recall any performance issues, but that makes sense with the vent issues. Good luck and let us know how it comes out.
McBroom
Denison Tx
Hemi 6.4L
After going back into 2wd did you back up the 60 or so feet needed to kick the hubs out?
I love my truck!
Blue Mule 18 Ram 4x4 C/C
Tradesman Power Wagon
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
the shift fork isnt fully disengaged. disconnect those lines and drive around, bet it wont light up
