Weird issue.
Mark Kay
Iowa
New here, first post. Twice now in 2 months when I start my 06 1500 Hemi, the ABS and Airbag lights come on and radio and signals stop working. Shut it off and restart it and it's fine. No other issues with truck. Thoughts?
Karlsweg
SW Florida
Check grounds and try resetting the pcm by unhooking both battery cables and touch them together for about 30 seconds. It is an easy DIY that may work. Have you checked for any codes?
Mark Kay
Mark Kay
Iowa
No codes come up. Will try what you said.
Thanks
rickv
Holtwood, Pa
2008 Hemi 5.7
I have a 2006 2500 Hemi that does the same exact thing. Air bag light comes on, and I loose, my heat, turn signals, wipers, and radio. Doesn't happen all the time. If I drive it for awhile, turn engine off and on, it goes out and everything is back to normal.
Mark, just curious if you fixed your problem?
rickv
Holtwood, Pa
2008 Hemi 5.7
I know this post is old, however, I asked a repair shop about this as it still happens with my dodge.
I was told the ignition switch needs to be replaced. It hasn’t happened in awhile and when it does I jiggle the key and then it works fine.
Fast69Mopar
I have experienced this issue many times with plenty of my customers and several of my own Ram 1500's. After tapping on the key cylinder a couple of times everything would be operational again. The key cylinder turns the ignition switch so when you jar/jiggle the ignition key it transmits through to the ignition switch and things start working again.
Get yourself a new ignition switch. Remove the upper and lower shroud from the steering column and you can access the ignition switch. Disconnect the large electrical connector from the ignition switch and remove the fasteners that retain the ignition switch to the steering column and remove it.
