weird shakes
crc13
Wisconsin
hemi
Hello, I am new here. I have a 2012 reg cab short box hemi motor. Love the truck. I have it lowered with springs and drop shocks. However, when I hit a bump, I feel like the entire truck shakes, kind of like it is too light and not sticking to the road. Weird feeling. Seems like the entire truck moves. Any suggestions?
ScrappyDogg
Louisiana
Hard to diagnose, but first and cheapest thing is tires balanced. If they are old, then one could be out of round. Whichever the case, take it down and have the rotated and balanced.. shouldn't be but 50 bucks. If it still doing it, raise front end off the ground and start shaking tires to see what's loose.. WHATEVER you do, use jacks, never use anything else. I had a bad experience once and if God didn't have that angel behind me, I would be missing 10 fingers at least.. trucks fall all the time. I still shake when I get under one.. good luck, hope this leads you somewhat in the right direction..
mikeru
Super Moderator
Moderator Supporting Member
Eastern WA
2020 Limited
Hemi 5.7L non-Etorque
Sounds like every Chevy I've ever owned. :p
There are lots of bushings that can wear over time and mileage. Pretty tough for us to diagnose from here. If this issue is something that's relatively new for this truck, I'd take it in and have the alignment checked. They can check for worn suspension and steering parts and give you a much better diagnosis than we can.
