Weird tail light issue
GreenGoblin
Lucedale MS
Just picked up a 2000 ram 1500 4x4 and I'm having a weird issue with the tail light. The passenger side tail light doesn't work but the brake light and blinker both work. Seems like if it was a fuse BOTH tail lights would be out and If it was just the bulb then the blinker and brake light wouldn't work either. Not real sure what could be the issue, any advice?
lpennock
Army
Phoenix, AZ
5.9L & 6.7L Cummins
Most likely the bulb. The Brake Light and Turn Signal use one filament and the Tail light uses a different filament.
GreenGoblin
GreenGoblin
Lucedale MS
The bulbs were the first things I changed, maybe I got a bad bulb though.
lpennock
Army
Phoenix, AZ
5.9L & 6.7L Cummins
Check the socket for corrosion since you already did bulbs.
Reactions: Mop
GreenGoblin
GreenGoblin
Lucedale MS
I checked for corrosion, also checked for loose or broken wires. No luck so far.
lpennock
Army
Phoenix, AZ
5.9L & 6.7L Cummins
Do you have AlfaOBD by any chance? If so you could check to see what codes the Body module is reporting.
Otherwise it is time to get the multi-meter out and start checking the voltages at the pins.
crcraft
