What ball joint tool is everyone using for UCA replacement?
RVA Ram
Richmond, VA
Hey Guys,
I recently installed the Fox 2.0's on front and rear and replaced the stock UCA's with the Zone UCA. It was a PITA to get the old UCA to release from the spindle. I bought a tool from autozone that barely fit. I'm wondering what tool is the correct tool for this?
12sportmc
NC
This ^^^. The manual says specifically not to hit it with a hammer but I've always done it that way and never had any issues. There is a special tool that you can get from Chrysler but the rubber mallet method is tried and true lol.
Fanta1500
Albany NY
Pickle fork from advanced auto, boom right off in a couple swings
Csanders1992
I used a hammer and wood. Took two hits
WilliamS
Tampa FL
Heavy hammer with a wood block. You dont hit the arm directly you use the wood to absorb most of the blow. Works pretty easy, give it a good whack itll fall.
808ram1500
Big Island, Hawaii
4.7L
Don't you hit the part on the spindle where the UCA ball joint goes into with a sledge hammer? The shock of the blow is suppose to free the ball joint.
