Are those the DTMoto ones from ebay? They look real good man!
Thought so. I ordered the same set for my truck and they should be here tomorrow cant wait!Thank you!
Yes they are. I can't believe how great they look. It's so hard to tell how they'll look from the internet. Had a small issue installing them since they didn't come with directions, so I called dtmoto and they said the connectors plug into where the actual bulb plugs into on the wire harness. After I found that out, I installed all 3 in 10 minutes. Pretty bright too.
Ya it does come with the 3rd brake light. Not a bad idea to make sure it seals good. Might have to stop by the auto parts store on my way home tomorrow....Awesome man! You'll love them.
Did you get the third brake light as well? If you did it comes with what felt like a felt seal that goes around the outside of the back of the light, I would assume it's to keep water out. I think I'm gonna take mine out and put 3m tape on it to hold it in place better or glue it to the light itself. I can snap a pic of it tomorrow if you would like to see it. Hard to explain
I might be interested in the steering wheel. Does it have sound controls on the back? Think it will fit a 2009? I want to get rid of the cruise control "stick lever" on mine.Went scavenging at a local yard for my next project. ...picked up a few other things while there, spent way to much, things will be for sale, priced to move!
Are those the Phillips "Lumi-Leds" LED Taillights all over eBay? I see DTMoto has ALOT of them for sale for around $168 shipped.
Are these ( http://m.ebay.com/itm/C-Strip-Desig...3500-LED-Tail-Lights-/131821695793?nav=SEARCH ) the same lights that you bought?
I like how they look on your truck and I wouldn't mind picking up a set if they are the same ones you got, seeing as they're only $163.
Sent from hell via TapATalk
do those lite work on the 2017 and did you have LED tail lights already????
Salutations Folks,
I was asked what I was thinking about doing about the rear bumper when I first joined the forum; since I already had installed and color matched the front Iron Cross Bumper, and IC LED Fog lights, and a KO Off Road LED light bar.
So, since I finished priming and painting the rear Iron Cross bumper, I also installed tail lights that light through the two plasma cut out cross's in the back and installed two Rough County LED Pod to each side of the the trailer hitch.
Also, installed a foot dimmer switch for my LED light bar, for those who think my low beams are high beams, and bright light me, for a snapper reply!
Done a few other things since I was last on here, but still have to hang out at the VA hospital for a while so I will update all that later.
I am having a rear tailgate RAM badge custom made with the Punisher Symbol and HEMI under that skull. It was my call sign when I was a First Sergeant in Iraq.
Very Respectfully,
George
