CanuckRam1313
Ontario Canada
2023 Warlock
Had a complete Krown rust control application spray.
Received my new OEM front headlight assemblies to install with my daughter this weekend (on my truck, one is like a rain forest in there, and the other is just starting to let in moisture).
Installed my new LED yellow fog lights, wired it in and ran the switch inside on the dash.
danielmid
Southeast WI
2015 Sport 4x4
New serpentine belt, idler and tensioner pulleys, NGK spark plugs, and a Noco underhood charger. Glad I bought that Gearwrench swivel socket but it still sucked. Plugs look good just aged at 105k mi.
Stefan N
Sweden
2015 Sport
both piston ceased in Caliper, it got werry hot before I got home :D
could not move them with a biig water pump pliers with hose removed and nipple out :O
BOOYA2YA
HEMI 5.7
So I had enough of that infamous “Tick”. Had 5 broken manifold bolts that I removed by welding nuts to them since they were below the aluminum heads. New exhaust manifold’s, new hardware. Certainly was easy up on a buddy’s lift. TICK BEGONE!
ramsare4real
FL
Rotated the tires today. I was going to flush the brake fluid, but it got too darn hot. Will do first thing in the morning.
RamDiver
Marlborough, Ontario Canada
2021 DS
How about sharing a picture of your truck with these fancy new fog lights? :cool:
Shadow Ops
Houston, Tx
I went to the beach Saturday, and proceeded to immediately get stuck in the sand, yay 2WD street tires! Got pulled out by a massively jacked up Gladiator. The sand was soooooo soft..
Edit: When I got pulled out, I stuck to the harder stuff and had a great time!
CanuckRam1313
Ontario Canada
2023 Warlock
Installed my new Fahren highs/lows this weekend, too, and adjusted the headlight assemblies.
Now I just need to adjust my new fogs.
I also had XPEL protection film put on my headlight assemblies and fog as well. Keeping them crystal clear and chip free is important.
metalchewy
Las Vegas
2010 TRX4
4.7L
I installed a new mopar door/window switch. After a couple rounds of the cheep Chinese crap, I ordered one through @AllMoparParts.com .
Works perfectly now for all windows, without having to tap it, press or depress the lock button and the other combinations I was having to do to make.it work.
