What does the ambient light control do?
JD Martin
Southeast
I read through the manual and all I can figure out is that it turns on the interior light in some fashion. I tried it a couple of times - mostly when I adjusted the wrong knob trying to dim the dash lights - and I don't see anything happening at all.
This is the rotary switch to the left of the dash dim rotary switch.
Ideas?
1500ram12
5.9L Cummins
The ambient light may be tied into the automatic headlight sensor. The lights itself is in the headliner console (if equipped). I don't think it's dimmable or can be manually turned off.
turkeybird56
Central Texas
Ideas?
Well, depends on yer trim. On MY 19, it dims or basically turns off the Center Console Light that is built into the Upper Console. On higher trim models, I do not know if it also dims the other ambient lighting, since I got a Bighorn. (Also, if the right rotary switch, lights is Turned up all the way, your ambient lighting does not work, at least on Bighorns, easy to see at night)
JD Martin
JD Martin
Southeast
Well, depends on yer trim. On MY 19, it dims or basically turns off the Center Console Light that is built into the Upper Console. On higher trim models, I do not know if it also dims the other ambient lighting, since I got a Bighorn. (Also, if the right rotary switch, dash lights is Turned up all the way, your ambient lighting does not work, at least on Bighorns, easy to see at night)
Thanks, I'll have to check that out next time I am driving at night. I have a Bighorn north edition group 2 4wd crew.
jdeere05
Indiana
Mine controls the lighting on the floors
Fantastipotamus
NH
Hemi 5.7 eTorque
I also have a Bighorn, and for me, the wheel dims a tiny light in the overhead light cluster between the map lights. It only works when the headlights are on, and it just shines down onto the console/cup holder area. It’s pretty noticeable IMO (but I live in the country), heard from some city slickers saying it’s nearly impossible to discern in any areas with regular street lights. :)
JD Martin
JD Martin
Southeast
I know exactly what tiny light you're talking about. I like that tiny light. I noticed it the first time driving back from NC through the mountains and thought "damn, that was a smart idea, whoever made that little light". My Titan had one also, but I don't think it was dimmable.
Hoythews71
Virginia Beach, VA
There’s also a light in the upper glovebox that adjusts with that knob.
stepbill
Aberdeen, North Carolina
Went by the dealer today and asked them that question and not too many seemed to know. One salesman told me that it controls lights that are mounted to the doors and you have to have that option for it to work. If you don't have it, then the dial does nothing.
JD Martin
JD Martin
Southeast
Well, I'll have to watch the stuff inside next time it's dark. I suspect you might be right in that mine doesn't do anything.
Rambutz
upstate ny
i have a rebel and it only lights up in the same place also
