Timeless
- Joined
- Feb 13, 2015
- Posts
- 210
- Reaction score
- 80
- Location
- South Carolina
- Ram Year
- 2019
- Engine
- 5.7 Hemi
I was wondering what he was actually talking about on that. I know that a lot of things on that big 12 inch screen is like a split screen but I wasn’t sure if he was expecting to be able to put Waze on that full big screen or what he was trying to do.
Yup I think only the built in NAV and Sirius/XM can be made full screen. It is still nice in that you can have Waze on the top and something else on the bottom (music, hvac controls, etc).
What exactly is the issue? When you start talking about putting a shut off valve on the coolant line that goes to the heater core, you’re starting to talk about the reason why these older big semi-trucks have the valves to turn that on and off because we have the same problem with some of our trucks that the ACs don’t get cold enough unless you shut the hot water off to the heater core which is primarily because of a blend door problem not isolating the heat from the cold where the airbox is in your dash…
This forum won't let me link to the other Ram forums so you will need to search there.
Again this is related to 5th gen Rams. The 2019 classics do not have the issue as they use the 4th gen setup.
