Clunking under passenger dash still cant find it unless I take whole dash off I guess.
What kind of clunking?
Projector headlights absolutely suck my fohs are way better than the headlights
Are you still using the same ****** factory bulbs, or have you upgraded to something far better because if you haven’t, that would be plenty reason to still hate them.
The blower for heat and a/c has never been strong as it hard to warm up inside on those real cold days
No cabin air filter
Have you added the cabin filter? If not, that might be a good next mod to do. It ain’t hard. It just requires spending a few bucks on the kit and cutting out the opening where it goes. But I don’t know about for if it’s always been that way but if you still haven’t added the cabin filter, you might have a plugged evaporator. Or you could have or always had a bad fan resistor switch. I don’t know if they still do but years ago for the third gens you could buy a heavier duty fan resistor that supposedly made your fan turn faster. Might wanna look into that.
Tailgate (I installed kit for slow opening right away)
But you still hate it? I guess it’s probably just me but I would think that if you’ve already added the tailgate damper that you’d no longer hate it… LOL.
Had 3rd brake light leak also satellite antenna leak as it was loose also
Again, sounds like you’ve got these two problems fixed so how can you still hate it? I mean, on one hand I can still understand hating it regardless but on the other hand, if you’ve got that fixed then why would it still be worth mentioning as something that you hate?
Floor heat actuator never worked I’m waiting for replacement in mail at my cost because dealership could never find a problem
So if you’ve found, and are pretty sure that that’s the problem, why did the dealership not look into that and verify that’s the problem if you’re sure that’s what the problem is, and have them pay for the replacement? That doesn’t make sense to me.
I am still getting a leak somewhere drivers side as it shows on my rubber floor mat when I get in.
Can’t help you with that one unless you’ve just got a bad door gasket that’s letting water in or you may have a leak in your windshield adhesive.
Rusting at seams on back bed welds between cab and bed where those rubber wetherstrips are. I’m constantly trying to reach in there touching up paint. Even tho I get truck protected.
I took a peak inside rear wheel wheels between the outer and inner sheets of metal and rusting real bad 1 yr later yet truck is 5yrs old now.
There is a five year warranty on rust coverage.
Oh and the shifter on dash hate it. I’d rather have floor shifter
Might want to just try to stop hating it and try putting some more effort towards learning to use it because the more and longer you end up hating it, you’ll never get used to it to where you can be ok with it.
To be honest, I never really was quite happy with the rotary shifter in my truck right after I first bought it but, as I put as much effort as I could in the learning it and getting used to it, I actually like mine now. Even over the column shifter which I’ve always had, and most definitely over that ugly console shifter. That right there is just an argument over personal preference and quite frankly, I’m glad they did away with the console shifter and went with that.
Still love my niw second ram and looking to get the 2021 or trx as my truck is paid off next week.
Well at least with that one, you shouldn’t have to mess with the tailgate, it’ll already have a cabin filter, should have LEDs in the headlights considering what trim level you go with or have it special ordered, I think they finally got the leaky high-mount brake light gasket problem figured out but it’ll still have that rotary dial shifter, tho.
