What have you replaced?
Fletch125
2014 Ram 1500
3.6L
I'm on my second Ram and was wondering what kind of work you guys have had to do. On my 2014 I replaced
-both upper UCAs (previous owner had spacers in and popped the ball joints)
-3 sets of sway bar links
-rear caliper
-both rear rotors due to the e-brake cable sagging and setting the parking brake slightly
-both front wheel bearings
Had the truck for 30k miles. Bought it with 50k. Never touched the motor but it was a v6 with the 8 spd. Trans had a really rough downshift. My newer 2016 is 10x better but not without fault. It's at 48k and already had the HVAC unit replaced. Now the front end has developed a knocking. Love these trucks but not the stupid issues.
Sent from my SM-N950U using Tapatalk
MADDOG
Living in a Firepit
6.4L HEMI
On my 2017 CTD, the water pump was replaced under a Technical Service Bulletin.
Steering box replaced under warranty.
That's it so far.
oh...had to replace the entire 2014.
MADDOG
Living in a Firepit
6.4L HEMI
LOL...Well, I had no choice in the matter.
BigRed4x4
Mid Michigan
105,*** on my 2014. Bought it with 50k so I have no clue what was done before I bought but if I had to guess... nothing. Did the rear pads and rotors and spark plugs around 85k miles and have an appt next tuesday for the lower ball joints.
Garce421
Are the 14s that bad? Hoping mine doesn’t start to go south on me it’s almost paid off and I want to get a few years out of it still
Black W900
Nashville, TN
Brake pads, tires, spark plugs.
I have 109,000 miles on it now and it has been totally reliable.
I'm scheduled for the tailgate recall on Tuesday.
armallard
North East Arkansas
2017 SLT CC 4X4
I was told Monday by my dealer that they still haven't found a fix for it. Maybe they found one since then. lol
Black W900
Nashville, TN
Your dealer is not telling you the truth.
I was in the parts department yesterday and the parts guy asked me if mine had been done yet, then he showed me the part that they got in to fix it.
He says that they have already done about 10 of them.
tourrider
Grumpy
NW PA
CTD 6.7
97' 1500 - bought new - after 237K miles in 10 years, I replaces tires, brakes, water pump, thermostat, and front hubs/bearings/exhaust. Did I mentioned I towed a bobcat skidsteer, and plowed snow (commercially)?
07' 1500 - bought used with 37K miles. rear pinion bearing failed at 120K, rebuilt entire rear end. Front hubs/bearings/ water pump/egr/blower motor/exhaust. Sold at 155K miles.
18' 1500 - no problems in 18K
18' 3500 - 920 miles, still no problem :)
6.7CumminsDrvr
The Dude abides………
Georgia
Ah, this is a good thread
Replaced the factory paint
Electric stearing rack twice
8 speed trans
All done within the first 20k miles
Almost forgot...........hoses due to funky smell and 3 exhaust manifold bolts (bolts done about 2 weeks ago)
TRCM
USN, Retired
Newport News, VA
2012 1500 Laramie CC 4x4
ha ha...on my 2012.........6 yrs old, but still below 27k........
oil & filter 6 or 7 times
W/W blades more than a dozen times (hate streaks)
transmission shifter mechanism (would not go into park when it was below 10 deg out, felt like a cable style shift mechanism that had ice/snow jammed in it) -> normal warranty item
power lumbar mechanism (just the switch was bad (slap the panel besdie the switch & it would work), but they claim they had to replace the whole thing) -> lifetime maxcare warranty item
RaftingDave
Colorado
Tires. BFG KO2's, bumped up a size. Lost a little on ride smoothness, but oh well.
Rabbitracks
2016 Ram 1500
All I did was replace the front struts with Bilstein 5100s at 2.1" for leveling (should have gone the 2.8", but that's history).
The Goodyear Wranglers wore out in 16K miles. Replaced them with BFG KO2s, 285-65 R20 (34-1/2").
Replaced the RA1 radio with a Sony XAV-AV200
It has Bluetooth phone, back up camera, XM Sirius, Apple Car Play and Android, wiring for sub-woofer, DVD player, etc.
I paid $500 for it installed and it sounds good. would sound better with the sub-woofer, but se la vie...
JohnKoegel
Rochester NY
Bought my '15 with 47k on it.
Came with a bad front wheel bearing, replaced both of them with Timken hubs.
Now at 61k replacing it again, but not until after the dealership finds the front end vibration/bearing noises that are causing the shudder at speed on the highway.
Other than that, just the tires, oil, and air filter swapped for a drop-in K&N.
great blue
buffalo, ny
3 issues I shouldn't have had. First over 6 exhaust manifold bolts broken flush with the aluminum block. Sounded like lifter noise but wasn't. Cost over $1500 to fix. Dodge "engineers" apparently can't properly stress a bolt. Second, rear differential bearings replaced, mechanic said this is common with pre-stressed units that are overloaded by the factory, cost $1200 to fix. Third, HVAC not directing air flow properly, failed actuators/servos. Did repair myself at cost of $60 per actuator. Broken exhaust manifold bolts pissed me off most, very difficult to remove and dealer actually hired a specialist to get them out. I now call my Dodge a Bick Truck, totally disposable. 2012 Dodge Ram 5.7 hemi, just over 100K miles.
brentwasham
San Antonio, TX
2013 Tradesman, metallic red with wheel-to-wheel black sidesteps and fender flares, factory wheels
No parts replaced on my '13 but had to disconnect the battery once to reset the system. Nothing would come on including the starter. Wish I had tried that before he $85 towing bill.
