What I learned replacing my speakers
macmongrel
Alaska
Question...Mines a laramie so it came with an alpine system...not even sure what kind of speakers....but id like to assume their better than what you described came out of yours right?
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
yes, those should be an Apline speaker, far better than the average paper/wizzer coned ones.
Miami Son
Miami Son
Banned
Port St. Lucie, FL
2012 Ram 1500 Sport Crew Cab
Man, I miss living 5 miles from the Fry's in Woodland Hills, CA. Not a single Fry's here in FL.:bawl:
Blackout, what speakers did you go with? As I said earlier, this appears to be a Kicker issue and not one with Dodge or their speaker openings.
Graygoose
Oklahoma
Convert, for now.
small
he and I both used the Kicker KS693's.....
blackout11
alpharetts GA
2011 R/T
I dont know i have the alpine system and they were still the cheap paper ones lol
and these are what i used as grey stated
and pretty sad you have to buy 4 to use 3
Miami Son
Miami Son
Banned
Port St. Lucie, FL
The KS series must have normal-sized baskets. :(
What do you mean by "had to buy 4 to use 3?"
B-RadsBadRam
Albia Iowa
HEMI
Miami Son-
All the door speakers are 6x9 correct? Tried to find some info on here but wasnt havin any luck for the crewcabs. Was gonna put the kickers in mine as well since everyone really seems to like them. Thanks
blackout11
alpharetts GA
2011 R/T
Miami Son-
Yes all 6x9 but becareful some fit some dont it seems
Joshwaa
Lake Worth, FL
2016 CC 4x4 Laramie AirRide
Have any of you tried the JL Audio C5 6 1/2" doors. They sound EXCEPTIONAL!
jbyeatman
2012 4x4 Crew Cab Laramie
Alpine I do believe, the 3rd goes in the forward center of the dash. Alpine also puts 2 speakers in the headliner above the rear seats.
Great info in this thread. Thanks. Anyone know the size of those two speakers in the headliner?
cjacks519
2012 RAM Sport Crew Cab
Agreed on the great info. I'm also wondering about the headliner speakers. Planning to upgrade soon too
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
king99
Lakewood, IL
I ran into the same issues when I did mine. Dash speakers drop right in and sound great. I went with 6x9 Kickers up front and yes I had to remove some plastic. Kickers magnet is deeper than most. And yes they do sit against the speaker grills in the doors. No effect on sound quality. I did have to space them a bit. Rears I went with 5.25's with adapter plates. I'm running a 10" sub so wasn't looking for any bass from rear speakers.
Crutchfield sells wire harnesses that are plug and play for aftermarket speakers for our trucks. I think I got all six harnesses for $30 or so. Eliminates soldering anything. Also it extends the length of the wires which in the dash makes it alot easier to get in. A fellow forum member was kind enough to point this out before I did my install. Glad he did.
Dash:
Speaker Wiring Harnesses For select 1990-up vehicles at Crutchfield.com
Doors: Front and Rear
Speaker Wiring Harnesses For select 1999-up vehicles at Crutchfield.com
Hope this helps guys.
jdeere05
Indiana
so is this like you said alpine? it dont affect the normal trucks with out alpine?
arod412
Philadelphia
josh, i was thinking about component speakers like this, but i decided against it, because i don't want to have to setup the tweeters and drill.
6x9 is what i'm planning on getting but i hope it gives me good bass.
garner
Harker Heights, TX
If you go with the kicker by mopar you will have no fitment or connector issues
ManBOOYA
