Craw
- Jun 22, 2017
- 589
- 254
- Location
- Western, Idaho
- 2013 Sport
- HEMI 5.7
Looking to have a jack, I keep in the bed of the truck. What do you use? All I have for traveling is the stock jack.
Question. I have aftermarket wheels and tires. 20’s and 33’s. Carrying around the normal spare sufficient. Or should I look in to a matching wheel/tire combo
All three of my flats were either going to work or going home from work. Just out of curiosity how long does it take for AAA to come change out a tire and get you on your way again? I haven't been late to work in over 20 years and don't want to start now. My old lady has AAA but she's never had to use it so I'm not familiar with the wait.
The spare should be sufficient to get you to where you need to go nearby for repair. I have 35's on 20's and am sure my spare would be fine. Not speaking from experience, just regurgitating what I have been told.
I have a full size spare that came with mine on a 20" steel rim 275 60-20. I read another member put a 275 65-20 spare under there and from what I can see it should fit although it would be tight. That's a 34" tire so close enough for the short term.The spare should be sufficient to get you to where you need to go nearby for repair. I have 35's on 20's and am sure my spare would be fine. Not speaking from experience, just regurgitating what I have been told.
A 275 60 20 is my spare tire and came with the truck. That's a 33" diameter so a good match as a spare. The fact that it's narrower doesn't matter.Question. I have aftermarket wheels and tires. 20’s and 33’s. Carrying around the normal spare sufficient. Or should I look in to a matching wheel/tire combo
Mine has a hitch as well. That's why the 34 is tight. Little more than 1/2" clearance around the 33 that's under there now.Yeah, I think it may be possible. I did some measuring and figured I would likely be able to fit a spare 35 m/t on a 20" rim under the truck. Would have to take out the resonator and dump my exhaust behind the axle or out towards the front of the rear tire and the hitch would need to come off. Unfortunately, I can't get rid of the hitch, so I dropped that whole idea.
