What lenght bolts for the Dodge Connection steering box brace on the 4x4 model?
ryangtp89
Just ordered the dodge connection steering box brace for my 1989 Dodge Ram W250 4x4 with a 6" lift on 37's
Also just received in the mail my brand new Borgeson upgraded steering box & steering shaft.
So on the website it says I need these bolts:
4 - 7/16"- 14 x 1 3/4" Grade "8" bolts
6 - 7/16" Grade "8" Lock Washers
6 - 7/16" Grade "8" Flat Washers
2 - 7/16" Grade "8" Nuts
Now I know I will need longer bolts because mine is 4wd and the info on the website is for the 2wd. And the 4wd come with a side plate.
So do you think 2 1/4" should be long enough?
Also what length bolts to go up into the cross member under the radiator? I'm pretty sure I don't have to do any drilling because there's already a couple holes and a slot there.
u2slow
BC, Canada
Cummins 6BTA
This is a copy of the factory bracket right?
Prob don't want more than 1/2" max unthreaded shank on that bolt thru the crossmember. Thats about all the crossmember, bracket, and a washer add up to.
