What rims for a 6" lift?
Kgames
Okay guys, I have a 2012 ram 1500 big horn edition and I'm going to put a 6" lift with 37/12.5/18 tires. I found for 13.5 tires what offset or backspace I need but not for 12.5. If anyone is running that lift and tires can you tell me what rims I need?
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
All depends on how much stance you want, how much you're comfortable with trimming, etc. There isn't one right answer to this question.
JLEW
KY
2011 Big Horn
I have a 6 inch left on 37x12.5x 20r +18 backspacing with a 2inch spacer, so it makes the wheels set at approximately at -32 backspacing. I had had a slight rub. I had to take make a small cut at the bottom of the front bumper(that is not noticeable unless you look up under the bumper) to keep the wheels from rubbing when turning at about half turn. I also have Bils let all the way out at 2.8.
