What size fuel tank?
alnelson14
Cummins
Need a fuel pump for my 2005 1500 quad cab short bed hemi 2wd. Apparently they came with either a 26 OR 35 gallon tank. Unfortunate, they utilize different fuel pumps.
Anybody have a definite way physically (short of draining and filling the tank) to tell which I have?
HemiLonestar
Navy Badge Coast Guard
MD
Either that or pull the part number off your tank
pajeepman
SE PA
5.9 magnum
I always thought the 35's only came with long beds
Sent from my SM-A205U using Tapatalk
HemiLonestar
MD
Three available for 1500's that year
TANK, Fuel
52113613AD 1 42, 62 EK0, EVA,EZ0 [NFV] (35GAL) - 42 & 62 means it came with the long beds (see legend below under "body")
55366067AC 1 41 EK0, EV0, EZ0 [NFU] (34GAL) - 41 means QC short bed
52113589AD 1 41, 61 EK0, EVA, EZ0 [NFW] EWC 8.3L (26GAL) - 41 & 61 means RC & QC short bed
BODY
62 = Regular Cab (140.5 WB)
41 = Quad Cab (140.5 WB)
42 = Quad Cab (160.5 WB)
61 = Regular Cab (120.5 WB)
ENGINE
EZA = 5.7L HEMI Magnum V8SMPI
EKG = 3.7L Magnum V6 MPI
EVA = 4.7L Magnum V8
EVD = 4.7L Magnum V8 FFV
EWC = 8.3L V10 SFI
So yes, if it's a factory install you are correct.
A
alnelson14
Cummins
TANK, Fuel
BODY
ENGINE
EWC = 8.3L V10 SFI
TANK, Fuel
BODY
ENGINE
EWC = 8.3L V10 SFI
So I guess I meant 26 OR 34.
thanks for the part numbers. I will try the vin link above and if that fails I’ll look for the markings.
HemiLonestar
MD
If you can't find a direct replacement (same size), don't forget you'll need a different front strap and the DTE in your overhead OTIS will be off.
Bill Knight
Picton, ON, K0K 2T0
My 04 Ram quad cab short box, my fuel tank is 26 gallons. I would have to agree that the long boxes have the 34 gallon tank. There's not much room under my truck when you look under it for a bigger tank.
HemiLonestar
MD
The extra size is kicked out forward
