mxblaster83
- Aug 25, 2012
- 426
- 18
- Location
- British Columbia, Canada
- 2014 Ram Sport
- HEMI 5.7
what oil are you guys running? is there a benifit for syn?
Huge benefit to synthetic, read the synthetic thread in this forum, all the information you need there. How I was introduced to synthetic is a long story, but bottom line I was testing a family members oil after 5k miles and it was still light amber. I said she must be mistaken the oil was still clean and she didn't need a change, and she pointed to the oil change sticker in the window and she hadn't changed it since. She used synthetic, I have been using it since. Plus better wear protection, it is the way to go.
I just filled up with amsoil. Price is fairly close to RP. But amsoil, RP, and redline are all great oils. Definitely not overkill.
you think RP is overkill?
I read occasionally over on bobistheoilguy forums and yep, Mobil 1 doesn't test well for the most part. Based on what I've read over there I now run Castrol Edge Titanium. About the same price as Mobil 1 but tests much better. It's good stuff.If you plan to run extended intervals then pick up the top 3 synthetics listed above. M1 is not really made to run extended intervals and does poorly in tests I have seen. They do change there formula fairly often so who knows. In tests I have seen there are few always on top. Amsoil, RP and Redline. I have heard sheafers is up there too but have not seen tests. If I am running local stuff and not Ams I use Valvoline personally never had a tick or engine issue where as with M1 I feel engine is noisier than with any other oil.
$miley
ready for camping now.
