- Jan 17, 2016
- 23,829
- 54,858
- 14 Sport
- 5.7
Does the grease gun go on and off the zerk if you don't try pumping any grease into the zerk.There is no issue with the fitting taking grease.
And it's an issue with every newer fitting.
I have a feeling the bushings aren't actually taking any grease,and you're pressurizing the coupler to the point it's hard to get back off the zerk fitting.
If you've been using a petroleum based grease for a few years,the bushings could of swelled to the point they won't take grease anymore.
I'm guessing you've been using a petroleum based grease,as you're not telling us what grease you've been pumping into them.
Did you try using the grease gun on something else,if it works fine there,then there's nothing wrong with the grease gun or the coupler,and if the coupler goes on and off the zerks that are giving you trouble,with-out pumping any grease into the zerk,then it's the actual bushing that's not taking grease,probably cause it's swelled to the point it won't accept grease anymore.
