Wheel offset question
TTC06
Missouri
Does anyone know the factory offset for the 2012 ram express 20x9 (i think they are 9 wide?) I am thinking of getting 20" xd rockstars with a +10 offset. i don't want the wheels to stick out really far. if anyone knows or has this setup i'd love to know what you think.
TheMaddog
DFW
Stock set up are +25.4mm
Those wont make your rims or tires stick out. Negative offset will do that to ya though. To allow a bigger tire for off roading or whatever
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
i thought the stocker 20x9s were +18/19?
quietpeen
2021 TRX
Hellcat
The chrome clad 20's are a 9" wide wheel with 19.04 or 19.05 mom offset like fastnugly said and the non chrome wheels are 8" wide and not sure on the offset but its less.
The wheels you are looking at won't stick out too far at all
ramhunter9
P-Star Jeep Wrangler
+10 is good ...
I went with a +12 on my new wheels because I didnt want the stick out ..
My Oem wheels are a +44 .. so if ya break down the numbers .. and the fender width .. my new set will sit out .5 inch past the fender .. perfect for me .
Your +10 will look great
fastNugly
Toronto, ON
2012 Dodge Ram Sport CC
Another question is, will you use stock tires or equivalent size? if so, you will be ok.
When you start getting into the 295's and then 305's you will want the more negative offset. Like a 0 or +1.
But again, it is dependent on what tire you will use now and in the near future.
Last thing you want to do is regret buying the wrong offset because you cant use a tire you want.
My 2 cents
craigsez
Novascotia,Canada
Im kinda lost with this off set stuff.....My thoughts were on my 2010 sport just to go up to a 22 inch srt wheel with a matching tire..Will i need those off set spacers and is that a dealer item or custom item..Totally new to this..
My plan is to fill up the wheel wells a lil more to give it a more street performance look..
quietpeen
2021 TRX
Hellcat
If your truck is 4x4 you will need 1/4" spacers. Can be bought online or at some auto parts stores and ebay
Ricky91
