Wheel spacers and lug nut length?
Little Red
NY, USA
Does anyone know how long the factory wheel studs are? I was looking at getting a set of 1" bolt on spacers, but I don't want to have to cut down my factory studs.
JCJ4290
2014 CC 4X4
I believe they are like 1.4" or something crazy like that. 1.5" spacers just barely clear them.
xrsman
Ontario
3.0 Ecodiesel
The 1.5's on mine actually stick out a tiny bit! Go 1.5 man, is definitely worth it!
Stock wheels and tires with 1.5" adaptors
Stock wheels with 35's and 1.5" adaptors
Little Red
Little Red
NY, USA
Damn, that's a long stud. Lol
I'll get some 1.5" spacers. I only have stock 265/70's, but I wanna bring them out so they don't look so tiny under the truck... plus I had 315/70r17's (35x12.5) test fitted, and the tire shop liked the wear foot print with 40psi in them on a 7.5" wide wheel. Might have to find a buyer for my AT3's with barely 4k on them. :D
Thanks for the help guys. :favorites13:
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
FYI - a 315/70/17 will rub with 1.5" spacers on stock wheels and only a 2" level. Just so you're aware if you go to put them on down the road...
Some stock wheels have indents in between the bolt holes on the hug side of the wheel that would allow the stock lugs to project into if you use smaller than a 1.5" spacer. I'd recommend checking out your wheels to see if they have that which would allow you to run a smaller spacer if you wanted to.
Little Red
Little Red
NY, USA
Thanks for the heads up.
I'll check the back of my wheels when my driveway drys up some.
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
315 70 17 with no spacers, no rub, stock warlock 17 wheels, 2024 classic 1500. It's all about the front bumper and tire brand and factory ride height
