Wheels and Tires
NdRoosta
Houston
2010 Ram 1500 Sport QC
Any suggestions on tires I should get? I'm looking at general grabber at2's, toyo open country at, and cooper at3's.
As for wheels, I only know of fuel wheels that I like.
Where is the best place to buy wheels and tires, online or in store?
and also
How wide can I go on a 4x4 w/ rcx level 2.5 in front 1.75 in back?
I'm wanting to stay in the 33x12.5 range, but what about offset for the wheels? I'd like the tires and wheels to stick out as far as possible without rub.
Thanks
BMD
2015 x1 and 2014 x2
Go with 295/65/20 tire size
Cyborg2337
South Jersey
If you are sticking with your sport rims (20x9) then Cooper and General are a little more limited with tire size. Very good choices tho, I actually have the Grabber AT2 and Zeons on my final list (still undecided). You can go 33x12.5, 305/50 or 55, 275/60 or 65, or 35x12.5. Toyo/Nitto, Goodyear, and BFG will give you some more options. BMD gave you a nice size for the RAMs but if you want to stay closer to 33 then that may be too tall for you. As for buying... best bet is to shop around locally and online. I know General is running a rebate right now.
As for width, you can always throw on some spacers. There are many threads on them as well. Aftermarket rims; I have heard of guys going up to a -44 offset. Not sure about rubbing tho. There's a ton of great info here.
Hope this helps some. Good luck and post pics.
N
NdRoosta
Houston
So I went to discount tire and I think I'm gonna go with 33x12.5r17 on a fuel assault -12 offset or a 33x12.5r18 with fuel assault or vapor +1 offset
Probably a Nitto, bfg, or a general.
Brady18
Tornado Ally-Oklahoma
I have 295/60R20 Nitto Trail Grapplers on 20X9 with -12 offset. The tires are 34.5 inches tall and 12.13 inches wide. With the -12 offset they stick out a decent amount. I also have the Rancho Quik Lift Leveling Kit (2" front level).
Bramo
